yellow_cad
I have an older 4-6-0 locomotive than I want for occasional usage. Went to get it going and the motor wouldn't run. Upon disassembly I see that both pos and neg wires were not attached to the motor. I can easily see where to re soldered the pos wire, but not sure on the neg wire. It almost looks as though it was intended to be mashed in contact with one of the metal axles, but I'm not sure if this is the case or it needs to be soldered and if so, where do I solder it? Thanks for any help on this. Jim
