As a new sort of user of DCC, I was wondering if there is an easy tyo follow guide to programming CVs that also covers things like switch decoders etc. It should, if possible, also cover the different ways, if any, that Massoth and LGB implement the protocol using their devices
I am almost okay with the concept but when it comes to actually knowing what is going on and how to do it, I begin to fall apart.
Whilst I can folow, just about, the clearer instructions like the ones that 'Muns' posts as help to others, I do not actually understand what is happening so have to follow parrot-like. If I was posed with a problem, I doubt that I could work it out due to the lack of undderstanding and only being able to follow the set of instructions.
It is like the old adage:
You are told....you forget
you see...you can repeat
You do...you remember
you study.....you understand
I think that I maybe half way between the second and third......... It is the combination of the process of inputting and knowing what you you are inputting that I really need to get straight
A lot of guys on here are 'unconsciously competent' having gone through all the processes of learning and that is the top place to be. But when it comes to explaining how to do what you know in terms that lesser mortals, as a dullard like me, understandneed, you need to take one step back which is 'consciously competant' ..... from my old lectures when I was training to be a teacher......
So that is why I need a primer in CV stuff
