Paradise
		Below is not intended as a proposal. It is to help evaluate the scenario between the 16mm NGM module specs and the LGB track system.
I have included the Association of 16mm Narrow Gauge Modellers module nominal track radius in dark blue with optional side tracks in light blue at 150mm spacing.
The red lines are LGB R2, R3 and R5 radius as nominal with optional side tracks in orange which are also spaced at 150mm centres so they are compatible with 16mm NGM modules.
The module board length measurements were done for each potential module edge with a trigonometry calculator using the module section degree and track radius. CosSinCalc · Triangle Calculator
Issues when using the 16mm NGM module 150mm track spacing for use with the LGB track system:
Is it beneficial to have modules based on an LGB nominal track radius R3 and R5 considering that points are available in R3 and R5?
LGB R1 and R2 curved track spacing is 180mm. A spacing of 150mm on small radius curves may have problems.
A double track crossover with a pair of LGB R3 points need at least 180mm track spacing unless the diverging routes are shortened.
A double track crossover with a pair of LGB R5 points need at least 158mm track spacing unless the diverging routes are shortened.
