IP engineering coaches
philbiddulph
15 Aug 2010
96
Hi all,
Having not dabbled in kit-building since I was a teenager doing N/00 gauge I was thinking of getting a couple of these for the winter.
http://www.ipengineering.co.uk/page... or bad on IP kits? Thanks all Phil
jacobsgrandad
1
As a novice I have built a couple of carraiges and the curly roof brake van and found thwm easy to assemble and finish and have no hesitation in recommending them. I have also recently tried a Brandbright coach kit which I found stronger, more detailed and easier to assemble, but thay are more expensive requiring wheels and couplings to be bought separately. I will rpobably stick with the latter but would not deter anyone from buying IP
yb281
7
Worcestershire
www.facebook.com
The newer IP kits like this are excellent Phil. If you've made kits before, you shouldn't have any problems what so ever. The IP kits are beautifully and very accuratley laser cut. The only slight criticism I have is that the wheels supplied aren't the best and you might consider replacing them.
Alpineandy
501
Alpennines
The laser cut kits are quite good but are let down a bit by the wheels and roof, like any kit though the final result depends upon the care you take in building it and attention to detail. They should keep you occupied through the long winter nights though and you will get the satisfaction that you built them.
Granitechops
Narrow Gauge 1/12th scale on 45mm</br>Quarrying &
7
Sunny Devon Uk
Although I usually scratch build, I bought a batch of 7/8ths IP kits & converted them to 1/12th.
nice kits, tho I do my own roofs, As my models are heavier generally, and have the propensity to occasionaly tumble 2 ft to the ground. I reinforce mine on the inside corners as unobtrusively as I can
