Hi,
I am working towards a new bridge that will use 2.4mm welding rods, for the vertical and horizontal tension rods, has anyone a measurement for the inside (where the screw thread is ) of a 2.5mm metric thread nut please? The actual size of the rods I believe is actually 2.3mm and I suspect will be variable to 2.4mm.
I want to solder these to the top & bottom of the rods in due course so they need to be a reasonable sliding fit, though they could be drilled out a small amount, though there is about 170 of them!
Got it wrong - - the rods are 2.4, the nuts will be 2.5mm! Changed the measurements over accordingly
Yours Peter.
Yours Peter.
