bigjack
Railways of all shapes and sizes G 00 and big en's
I need some advice. I have had my first attempt at using LED's in wagons. or thought the white light is a bit on the bright side, I'm quite pleased with the result.
My question is this, I've looked at a couple of LED resistor calculators
This one http://www.hebeiltd.com.cn/?p=zz.led.resistor.calculator#series and this one http://ledcalculator.net/ . Now if I use a 9 volt supply, and 2 LED's do I take an average of the LED voltage drop ie Red 2.1 and Orange 2.2 making an average of 2.15v and put that into the voltage drop box and then 2 LED's into it's box?
The next question, one calculator shows the resistor on the positive side and the other shows the resistor on the negative side. Which is right or, are they both correct?
Any help, much apprediated.
