Thank you for that review! i have taken off most of my LGB track joiners and put rail clamps on them. I am now a "rail clamp purist" as this has been the BEST investment in no-stalls, no-derailment track work. I have a indoor layout and now I know that the tops of the rails with dirty track has very little to do with power distribution to my engines.
What I have found is that new track will run for only so long without your trains "burping" and stopping on dead sections. But the problem is not the top dirty track...the problem is that dust and grime has got into the rail joiners between the track pieces, if you can prevent that from happening or lessening its occurrence you will experience much better running.
Forget the "spider wiring" that is recommended for good power distribution; its true i only have a indoor layout, but i currently use a 1.6 amp trafo that puts out 19 volts max...i have one main feeder on each block (i currently have four blocks). The thing that keeps my trains going fast or slow, without an unwanted "halt!" is rail clamps. Also you never have to worry about a derailment from track coming apart.
Always remove the factory joiner before you install rail clamps. This tool you purchased will help me and especially my brother who has an outdoor layout and for whom I will be buying this and many packs of rail clamps. He uses LGB MTS digital and this is the ticket to constant fun and minimal hassle.
I do not use Hillman clamps, I have found a gent on Ebay that offers very high quality clamps. I will post the company when I get the details.
Regards,
Tom M.
