collectors
Thanks, its not an easy one. But no fun if it was.I have converted a 20212, details on my blog:
LGB Stainz Battery Conversion
The End Result Having never ventured in to ...tumble-down-falls.blogspot.com
I also believe thatge_rik did a conversion link below:
How I converted an LGB Stainz loco to battery power - Version 2
Narrow gauge large scale model garden railway. Battery powered, radio controlled locomotives, some Bluetooth. Set in Cheshire UK in 1930sriksrailway.blogspot.com
I think your right & i am looking around for a coal tender. It looks a little tight fitting in the train & i can increase the amperage using a coal tender. Might have to be a 4 wire connector for lights.Or, you can put everything in a trail car and connect with a two pin JST plug
How I converted an LGB Stainz loco to battery power with a trail car
Rik
It might be easier, to use the existing connector, plus 'something different' for the other pair of wires?I think your right & i am looking around for a coal tender. It looks a little tight fitting in the train & i can increase the amperage using a coal tender. Might have to be a 4 wire connector for lights.
PM sent, Chris.I think your right & i am looking around for a coal tender. It looks a little tight fitting in the train & i can increase the amperage using a coal tender. Might have to be a 4 wire connector for lights.
