"HELP" Where can I get LGB MTS Decoders Repaired
Gareth
Railways,Transport, Wildlife ,History
Have had 2 decoder throw a wobbler have traced the problem to cause of problem but has cost me 2 decoders one causes a short and th other will only let loco run backwards so I feel that these are,nt to serious and can be rectified both I feel cannot be exchanged for warranty so is it possible to repair them and where or whom can repair them Advice appreciated !!
I'd talk to either Jeremy at Dragon or Brian at Glendale. If they can't do anything themselves, I would guess that Massoth might be able to repair them at a price, as they are almost certainly Massoth-made in the first place. Whether it is actually worth shipping them off to Germany is another matter, of course.
This isnt a gloating reply im genuinly sorry to here your troubles but its one of the main things that puts me off going down the digital route, yes i know there are lots of you out there with trouble free dig setups but untill the prices come down to OO/ HO standards il stick with two wires and something i can repair myself
Good luck Hope you can get them repaired
Tony
Tony
I doubt if they will come down so much because they are low volume sales., unlike ho/oo
Gareth,
What type of decoders are they.....55020, 55021, 55022, 55027 or onboard?
Dont want to sound negative but the cost of repairing them may not be cost effective.
Had a word with Jeremy of Deagon G scale he suggested a way out . will try this "He Does not repair decoders as he feels they are not worth it he was very sympathetic though " Will try his idea .
Glad to hear you got a good response from Jeremy, even if he couldn't actually help with repairs - he's (in my experience) probably the most friendly and helpful G scale dealer in the UK - I've bought a frightening amount of stuff from him in the last couple of years as a result.... ;)
Good luck with whatever it is he suggested you try!
I blew up a couple a few years ago. It was obvious which bits had failed as it blew holes in the output transistors.
We had a chap in our local club in those days who was good at micro soldering, under a magnifying glass, who replaced the offending bits. Unfortunately he is no longer a member of our club but there are people around who can mend them.
A while ago I managed to repair a Lenz Gold Maxi by replacing the FET output chip that had obviously blown - fortunately I could identify and source the component from Conrad. As Mike (Dutchlem) says, you need to be handy with micro soldering.
Although it worked, the decoder was never quite the same again (probably some other component had suffered and was on the verge of failure) so I withdrew it. To be honest I tried the repair more as a challenge: it was significantly cheaper than buying a new decoder, but fiddly. Don't think my eyes would really want to try it again!
If it were me, I'd just source an alternative decoder - probably another cheaper brand unless there's a compelling reason to continue with LGB/Massoth because of a unique feature you need. Depends which LGB decoder it is I guess?
It sounds as though they are in the same loco.Is that right?
If so why not go for a massoth XLat less than £60.00 and can handle up to 3 amp.Sure Brian at Glendale can advise
Thanks for all the advice have aquired 2 new decoders and will settle on Massoth for future use I feel they are better laid out and seem more robust.
