HI THANKS WILL CLEAN TRACK BUT I THINK WHEN THE TRAIN IS OUTOF SIGHT IN TUNNEL MADE OF WOOD IT MAYBE LOSES SIGNALYes, I don't see how the WiFi would affect it, you might lose comms with the central station (NMRA command station), but that should not affect what is sent on the rails.
Could be dirty track, and a difference in "keepalive" duration between decoders.
THANKSIf some locos are losing power and some aren't it may be the quality and quantity of power pickups. Clean wheels and make sure brushes aren't worn out. Once you have cleaned track and loco then you can start some more specific detective work.
The signal to the loco comes from the track if you are using Massoth DCC, hence my suggestion that the track needs cleaning in the tunnel.HI THANKS WILL CLEAN TRACK BUT I THINK WHEN THE TRAIN IS OUTOF SIGHT IN TUNNEL MADE OF WOOD IT MAYBE LOSES SIGNAL
The wireless unit transmits to the command station, not the loco, the command station puts the signal on the rails.
The mountain could be made out of sheet steel and it would not make any difference.... the loco picks up the signal from the rails.
[/QUOT
I'm not saying that at all. I said wood shouldn't stop a signal. Relevant if the locomotive was radio controlled, battery powered, as smell of the folks use
When we are talking about Signal are we talking Radio range from the hand held controller? If so Massoth make a range extender for their RC, easy to fit and made all the difference to my setup when installed. I found that almost any building could effect the original RC setup.HI THANKS WILL CLEAN TRACK BUT I THINK WHEN THE TRAIN IS OUTOF SIGHT IN TUNNEL MADE OF WOOD IT MAYBE LOSES SIGNAL
Thanks will look into thisWhen we are talking about Signal are we talking Radio range from the hand held controller? If so Massoth make a range extender for their RC, easy to fit and made all the difference to my setup when installed. I found that almost any building could effect the original RC setup.
Product search – Massoth Elektronik GmbH
www.massoth.de
Hi I am using massoth 8136501 DiMAX 1210Z Central Station – Massoth Elektronik GmbH. And Rc Navigator massoth also of all my loco the Bachman steam engine is not affected.but the LGB loco 4/4 is and so is mth dieselIf this is 'classic' DCC, then it is a "power-to-loco" problem..
1.TRACK:
1. Power-feeds?
2. Clean track?
3. Joint problems?
2. LOCO:
1. Skate stuck 'up'?
2. Wheel-treads (tyres) dirty?
3. Back of wheels dirty / carbon brushes worn?
4. Lack of continuity down each side of loco? - ALL wheels and skates connected??
5. (less likely) busbars etc. in motor block contaminated with oil/grease, so insulating?
6. (really unlikely) intermittent wiring fault / intermittent decoder problem?
IF the OP is using a wireless DCC product, then yes, there may be a wireless-range / reception problem.
So, question to OP:
Exactly what system are you using? - Model numbers if possible, please? - Thank you.![]()
