I have had a look and carn't see another thread you have started, ones you have added to but not started.
May I suggest that you click on your "Name" in the top R/H of the screen and then select "Your content" from the drop down box, and have a trawl through what you have posted you should find
something to jog your memory.
Any you have created should also be present in the ‘Watched’ lick the blue Forums and Watched is on the white line below. I would suggest if it aint there it probably got lost somehow, we did have an outage last weekend for software work. If you tried to add it whilst that was occurring you may have had the issue you describe.
With Phil Jensen no longer in the Hartland parts business, I wondered what happened to Phil’s inventory and if anyone has found a business supplying Hartland (and Kalamazoo) parts? I am restoring a Kalamazoo Civil War (Union) 0-4-0 and need the drive wheel hub and spoke units. I have three...
