these sleepers are used very often in Germany for about 10 or 15 years.
 They are much cheaper than concrete sleepers and much lighter, too. Concretes are expensive and have to be very big and heavy to stay durable. light conctretes are breaking fast under load and weathering.
 Wooden sleepers ARE a problem, engineering tries to give durable solutions. And for more: wooden sleepers are expensive, too.
 The old steel-sleepers (looking somhow like ordinary wooden sleepers, just oxide-red) are a problem, too.
 relatively cheap and well to be set in, they tend to oxidate from below. Often, the seem to be o.k., but fishplates break through when u drive on with heavy load.
 For more, the old steel-sleepers are difficult to maintain, because it isnt easy to bring balast under them.
 So, the y-sleepers are a good solution. the are of "I"-shaped steel, in big amouts easy to bend and to build.
 The are more durable than the old steelsleepers and weight is on durable structures. there are no hidden "caves", where oxidation can go on without beeing detected.
 The changing positions of the fishplates and changing side of the y-shape gives very stable set in on the balast, while the flexibility is fine.
 y-sleepers are very good for lines where there are sharp curves and much circuit.
 Many minor lines in Germany were reactivated or the circuit changed: light trains, often railbusses, but much more velocity than in the older days. So u often have  a "light"-built line with sharp curves and light railbed.
 Upgrading those lines for higher speed is the mayor purpose of y-sleepers.
 for example:
 most minor lines in Germany often had Vmax of 50km/h.
 Today they have 80km/h with high frequency. Thatfor the y-slpeers are predestinated.
 Greetings
Frank
