Software Tools
The newish LGB High End crocodiles are very heavy locos, weighing in at 8.8 Kg in unpacked running condition If you are fortunate enough to come across one do not attempt to pick it up by the central body section (a favourite grasping point for the plastic bodied LGB crocodiles)..
The roof on the central body section on the 26600/01/02 crocodiles is held in place by small magnets which are adequate to keep the roof assembly in place but nowhere near strong enough to take the weight of the whole loco. If you must pick one up, take a firm grasp with an hand on each hood section.
Also as a general note, the package the loco arrives in weighs ~13Kg and the long box makes it tricky to handle. If you are going to lift the box, you need to have a very clear idea of where you will be putting it down again, The packaging has metal plates inside the carboard ends and a metal base plate that the loco is bolted to.
