Graphite paste with railclamps? Opinions please?
Zerogee
Clencher's Bogleman
1,723
North Essex
I found the paste works really well outside to keep water out of gaps. As it freezes it causes things to push around at the joints making poor connections.
For a moment there I thought you were referring to the graphite paste freezing, and thought "wow, that's a HARSH winter!".... then I realised you meant the water.....! ;)
itsmcgee
18 Apr 2012
346
344
Spokane Washington USA
Thanks for clarifying Jon. Sometimes the words don't match the picture in my mind. We'll call it an old age thing.;)
phils2um
Phil S
11 Sep 2015
1,522
423
Ann Arbor, Michigan
United-States
I've been using a dollop of graphite paste in the "fishplate" with over-joiner Split-Jaw clamps. I figure it's cheap insurance. But none when using rail-end Split-Jaw clamps.
Phil S.
stockers
3,795
65
Nr. Ashford, Kent. England.
I use graphite grease with Massoth clamps. Does it work - don't know, but I'm happy.
8 Mar 2014
7,806
972
San Diego
Armenia
www.elmassian.com
I have found clamps where I did not use grease, everything was shiny underneath.
I have found clamps where I did not use grease, and there was oxidation underneath
Grease is cheap.
Grease goes in my clamps and on the screw threads.
Cheap and easy insurance.
Reactions: 3 users
Zerogee
Clencher's Bogleman
1,723
North Essex
Thanks all, the consensus seems to be that clamps are good, paste is good, so clamps plus paste are even better!
That's what I was always planning to do, just wondered if there were ANY potential down-sides to it - it appears not, from the responses so far, so I will stick with the original plan..... :)
Madman
2,953
Pennsylvania, USA
And which plan would that be ? Plan A or plan B ? Or you could go with Plan 9 From Outer Space.....:rofl:
Zerogee
Clencher's Bogleman
1,723
North Essex
"I love it when a plan comes together...."
Madman
2,953
Pennsylvania, USA
Marcel Geleijnse
Valvefreak
24 May 2016
4
Reading, UK
There have been several threads recently about cleaning rail ends for tracklaying, all very interesting, and there seems to be a general consensus about using a drop of graphite paste, copper slip or similar when using fishplates for rail joining.... but do folks here still use it when replacing the fishplates with clamps?
Specifically Massoth type clamps in my case, but comments on others (Hillman type, Splitjaw etc, and Aristo track screws) are equally welcome....
Does some paste still help with maintaining good continuity even when you're getting a tight physical connection via the clamp?
As most others said before, tight screwed connections will stay shiny.
I have a mix of fishplates and used conductive copper paste, sparingly, on the fish plates.
With some you find it is difficult to get it in one half of the fish plate as it's held in place by being punched locked to the track, a tiny brush comes in handy.
The grease conducts and keepsout the water that oxidizes the brass track.
You only need a tiny amount and keep if off the running surface of the track.
Sean.
Hmmmm
5 Oct 2017
2,995
1,086
66
Boston & Cocagne NB (not enough)
Hey your working on the joint .. It takes a sec to add some grease .
I use it and think it's worth the effort ..:rock:
Zerogee
Clencher's Bogleman
1,723
North Essex
Do you also use railclamps, Sean, or just rely on the joiners and paste?
Zerogee
Clencher's Bogleman
1,723
North Essex
Sean.
Hmmmm
5 Oct 2017
2,995
1,086
66
These are pretty much identical to the Massoth clamps that I and many others over here are using, in fact they are probably all coming out of the same factory. So, returning to my original question at the start of this thread, you still use the paste/grease WITH the clamps?
Yes
Zerogee
Clencher's Bogleman
1,723
North Essex
Belt and suspenders
You REALLY don't want to say that over here, Greg - to the British it conjures up some strange images, some good, some not...... :rofl::rofl::rofl:
We say "Belt and braces", because to us "suspenders" are the things that ladies wear to keep their stockings up - what you guys would call a Garter Belt, I think..... it has been a source of much juvenile amusement and confusion over many decades...... ;)
Reactions: 1 users
