Gluing passenegers in place
Doug
Live Steam, scratch building
Ok, whats the best glue to use to glue passengers to the seats on an LGB coach?
Hot glue?, Silicon sealant?
Blue-tac is pretty good and removable. Also, many use silicone - again because it is removable.
I concur with the previous posts, I've used Blu Tac for years with LGB.
During my recent efforts with cheapo Chinese coaches and figures I chose to use a hot glue gun that I brought when it was on special offer at Aldi. I did find the hot glue a little stringy, probably due to my inexperience in its use, but it was easy to remove the stringing afterwards.
I use silicone but the annoying bit is what to do with the rest of the flippin' great cartridge after I have used only a miniscule amount.
buy more passengers :bigsmile::bigsmile::bigsmile:
Or, you can small tubes of silicone at a chandlery :thumbup:
Isn't the stuff you buy from chandleries Polyurethane based, as silicone based ones don't last as well?
Cheeky Monkey said:
Bet your shower never leaks:laugh:
I buy tubes from Wilkos and take care to pick tubes with a screw cap on the end which reseals the tube,
And I use a decent dispencer:love:
Are you suggesting mine is indecent?:-
[/quote]
You mean like a crowd scene.....?:wave:
Silicone, Blu-Tac, chewing gum anything that is to hand and that is easily removable if you need/want to have a change
cut a peasce off insulation tape, cover the end off the nozzel with the tape, sealing it, the sillicon cures by the air.. you might get a bit going off in the end off the tube, but its easly poked out after 6 months
I use Bostik Sticky Dots - generally cutting the dots in half, then use 2 halves per figure.
I find them really good as the can be peeled of to recover the figure and leave the coach as new - and they are also transparent.
Typically I use 2 halves, but some of the heavier figures need more.
I haven't found any brand of sticky dots to be superior another...
Craig
I don't buy any product, not that im tight, i raid wifey's toolbox for dollshouse Tacky wax it's really good and removable
