Sorry folks, me again...
For the experimental part of my experiment, I really need to know how much gas I'm using over a fixed amount of time; getting the loco to run consistently over e.g. a gas tank full for say 30- odd runs might be a bit of a challenge! So ideally I need a regulator that I can fit directly to a butane bottle, with some form of flow meter so I can set the gas to a fixed consistent rate for each run, and then time it so I know how much I've used.
Does anyone have any ideas as to where I may procure such a device, or failing that how I'd go about making one?
Thanks again folks.
The plan is to raise a known amount of water to a certain pressure in the boiler; I can work out how much energy that takes from steam tables. If I know how much gas it uses to do that I can work out how much energy there was in that gas, and get an efficiency; obviously it won't be the true burner efficiency due to all the heat transfer losses, but I can get a relative efficiency which is what I actually need, as the losses will be constant.
As the burners will be most efficient at different gas flow rates I'll use a variety of flow rates for each burner- I'll probably do 5 runs at 5 different flow rates for each burner.
Thanks again folks.
