Garret Shelf Queen
Clive Elesmore
17 Dec 2009
207
Guernsey, Channel Islands
Well after a certain amount of exposure I have got my Garret off the shelf and tipped it on the side to see if I could see the build number. I used a torch and looked underneath. Found the made in China and QC labels but no number.
I would like to find out and find if it is a first or second run as tac alluded to the other day. Tomorrow I will visit the shed where the box etc is and see if there is anything there.
Any clues. Clive
Doug
Live Steam, scratch building
8
West Herts
The first and second batch only have the steam going through the superheater. The third and final batch split the steam just after the regulator, one pipe goes to the superheater, the other pipe direct to the rear engine. Just look in the cab.
Midwalesstokie
South Wales
Sorry to be a pedant but Garrett produced traction engines. Herbert William Garratt produced the articulated steam locomotive.
You should give it a run now you've got it off the shelf Clive!
R J Mitchell
5 Feb 2010
18
And a Garret with one "t" is a room on the top floor of a house!
Clive Elesmore
17 Dec 2009
207
I stand corrected. It will not get a run this time but hopefully next time. I need to start collecting rainwater and need some new butane cans.
I will look in the garage tomorrow pm an see if I can find a number on the original packaging. I think is should be a late one considering the delivery date. I had better see what batteries are in the tx as well.
Cheers Clive
24 Jan 2010
816
60
Porthmadog, North Wales
www.rhoshelyg.me.uk
Third (final) batch locos can also be easily identified by having two metal strips across the tops of the cab doorways. These give the cab structure more strength.
E
Elmtree Line
Guest
Clive,
That, sir, is a beautiful engine.
Put it to use like it was built for, shelves are for tacky ornaments not steam engines! :confused:
steamtom1
Live Steam
443
5
mssls.info
To emphasize the name difference, here is a picture of a gentleman named John Garrett, running his Accucraft Garratt, with my 1:32 Pannier in the foreground...
palmerston
trains
14
Netherlands, near Aachen ;-)
Underside running board, behind bufferbeam fronttruck =ser.no sticker
Clive Elesmore
17 Dec 2009
207
Good morning Palmerston
thank you for the information. I should be back there on Friday next and will give it a look. Thank you to the other gentlemen as well and she will run soon.
It was interesting to read the posts on colour and seeing Mr Garretts black engine with the Pannier plus the later Welsh Highland shots I think I am happy with my black one.
Should be a picture attached of when I rode behind "Millenium" on 17/10/2006 which prompted the wish for the green one.
Have a good day running. The Countess could run for the first time today. Subject to duties!
Clive
