Im wondering if working G scale dets could be made from .22 rifle amunition?? Im talking about just the brass cartridge, turn the ends off in a lathe leaving little round disks...
We used to use something similar for scaring the bejabours out of new recruits in simulated explosive atmospheres. You could rig it up to work like the old Triang OO fog hut. A passing train could set off the trigger which would explode the blank hidden inside a lineside building.stockers said:You can get .22 blanks for starting pistols without a licence. They are based on the rim fire principle - the fulminate (the bit that starts the bang) is trapped in the rim of the case and is squashed by the hammer (firing mechanism). This causes it to explode.
Three problems with making a detonator.
1. It needs quite a bit of pressure to detonate, far more then the weight of our locos
2. The blank will just burn with minimal noise unless it is constrained by a barrel or similar.
3. As Michael Cane said - your only meant to blow the blinking doors off - you might get more than you expected.
Link to pic of blank - NOTE; Picture shows ammunition!!!
http://www.countrysupplies.com/item...2+(6mm)+Crimped++Blanks+For+Starting+Revolver
OK if you wish to go into guano production!yb281 said:This might sound silly, but it would certainly clear your railway of pigeons.
stockers said:Do they still make them? I would have thought some 'elf' would have banned them by now (which would be a shame).
Whe I was Traffic Manager in Kilmarnock we were supposed to remove out of date dets and take them to Irvine CCE depot, where - according to rumour - they were simply chucked into the sea! I found it more entertaining to take them to a remote signalbox called Barony Junction and get the NCB shunter to run over them. Yes I know, little things.....J2s said:When I was a shunter I used to destroy any out of date dets that I found on brakevans etc. by setting them down on the rails close together and gettin a driver to run em over. I think the most I did at once was 20.
Great fun to put a hand full of it around an ant's nest too .............. or so I've been told.KeithT said:That strikes a chord.
In the chemistry lab many eons ago to liven things up we used to spread orange crystals - potassium chlorate it think it was - on the floor and as the chemistry master walked around pontificating they exploded each time he trod on them.
Highly amusing to a class of 15yr olds.
Of course he rumbled us.
Result? Detention. :wave:
