Starting with just the basics where in the circuit are the fitted, across the motor or track connections or someplace else?
Cool but how do I download it...I just keep going in circlesWe have this area on the forum known as Resources, DCC, DIY & Stay Alive Voltage Buffers, 55021 is the first item!
What's the colour band for 1%?Hi Graham, all my DIY versions use 0.25W 1% resistors, the first ones I made, used 5% tolerance resistors and the Central Station used to "trip out" frequently, after carefully measuring their resistance value, a 5% swing on Far Eastern sourced resistors was a gross understatement, swapped them out for 1% tolerance, problem went away, CS stopped tripping out.
