Thanks Nick. I was wondering if Bachmann's smaller 24 mm wheels would fit. Most likely not.
Even the LGB ones tend to bind slightly, not sure why but they did on my Feldbahn Tram Coaches and Grizly Flats Opens. All sold on now.Thanks Nick. I was wondering if Bachmann's smaller 24 mm wheels would fit. Most likely not.
Jon, I found that the tram coaches and opens didn't have the axle inserts that the wagons have. Without the insert the floor rests on the rim of wheel. I fitted washers to the axles and this eliminated the problem.Even the LGB ones tend to bind slightly, not sure why but they did on my Feldbahn Tram Coaches and Grizly Flats Opens. All sold on now.
That should be useful advise for anyone that had the same problems that I had.Jon, I found that the tram coaches and opens didn't have the axle inserts that the wagons have. Without the insert the floor rests on the rim of wheel. I fitted washers to the axles and this eliminated the problem.
I think it's more a question of not using tight radius track.Slaters wheels, whilst very good, have a significantly smaller flange profile so you need good trackwork.
