Hello all and a Happy New Year to you,
I think this may be the correct place so here goes ...
I currently have 2 separate Lines with seperate power supplies to each as looking at running poss 2 trains with sound on each, (approx 6 amps) and poss even a double headed train so amps go up to around 9/10.
Im looking at putting a depot in off 1 line which will have space for around 10 locos, if they all have sound fitted im thinking there will not be enough Amps to run the 2 trains and shunt the shed ?, ie ... 2 running trains =6 amps + shed locos = around 20 amps, so my question is do you think it would be an idea to put a seperate power supply to the depot ?.
I have Massoth central station and a booster so if a seperate supply is used can I use another booster ?
Thankyou very much for any replies
