DGE-Railroad
The Orchard Line
Hey Maxim, fantastic work.
Given your knowledge with ESU, can you advise me please?
I am trying to test the large ESU smoke generator with an XL4 and the Lok programmer board
The programmer board isnt capable of powering the smoke unit in this setup I've discovered, so I'm using a small power switching circuit.
My question is whether the ESU software sh old switch the smoke yellow or green wire via the decoder aux terminal? I'm using yellow at the moment which I think is correct, but the smoke unit doesn't come on when the smoke function is triggered?
At the moment I have the yellow smoke wire connected to aux1 on the decoder, with smoke in f6 but f6 maps to aux2
The Aux2 function output is set to trigger the smoke chuff with aux1 set up as an ESU smoke unit
I think it may just be a case of moving the yellow wire to Aux2 for the chuff trigger, but the ESU manual shows yellow to aux1!
I'll m totally confused. Can you help?
