TONYWARD50
Tadpole sexing</br>
Hi chaps. A colleague has fitted and programmed an ESU Loksound with the sound for the Piko TEE Unit. We know it is correctly programmed as it works perfectly with the ESU Programmer and test track.
However, when he connects the LGB MTS (Mk3 ?) Handset, the loco moves ok but a lot of the sounds are missing, and whereas F2 should be the horn (as it is on the test track) the MTS switches the sound off altogether.
I have tried the same with my NMassoth Dimax and it is fine, so it suggests a problem between the decoder and MTS.
Can anyone shed any light, please ?
Regards
Regards
