Engine Shed
silverflyer
G Scale, Photography,
248
Harrogate, North Yorkshire
Here's my first go at building an engine shed for my proposed "Zillertalerhof" garden railway.
Sorry about the wind blown garden light in the background.
[attachment deleted by admin]
whatlep
1
Worcestershire
www.facebook.com
Very, very nice! :applause: Any chance of an article on how you did it?
mike
Master at annoying..
4,448
Rossendale
greatlooking engine shead, are the doors real wood? :applause: :applause:
Bram
Playing trains, Ballroom Dancing, Good Food & Wine
4
Knowle
That looks very good, any chance of a bill of materials
silverflyer
248
mike - 5/11/2009 3:37 PM
Yes the Doors are wood, i'll try and list what i used when I get a bit of spare time.
Bruce.
mike
4,448
Rossendale
its the detail on the doors, hasps, locks ect that make it look brillent :)
Bram
4
Knowle
The detail is brilliant
ge_rik
1,244
Cheshire
www.riksrailway.blogspot.com
Is the roof moulded plasticard?
How'd you do the paint finish - the lichen is incredibly realistic
Rik
stockers
3,795
65
Nr. Ashford, Kent. England.
Very nice. Brilliant colours on the roof.
silverflyer
248
As for it's construction here we go:
Wall made from 6mm Foam Board with a timber frame glued inside with WP Adhesive.
Roof is Plywood and the whole thing was given three coats of Sandtex exterior paint, which when dry spray was coated with Thompsons water seal.
I am still wating for the Roof Tiles to arrive from Germany, so what you see at the momment is only a phtograph. the ridge tiles are only stuck on temp till the tiles get here.
Plastic upvc angle was used for the corner trims and round the windows.
The alloy guttering was made by cutting strips of alloy 0.75mm thick into 15mm wide x 190mm bits which were placed over a groove in a short length of deck board,
I then placed a length of 6mm mild steel rod over the top of the alloy and stood on it. The down pipes are made from 6mm alloy tubing.
Windows came from Bloxs in Germany, they come complete with glazing at about 3.5 euro's each.
The whole thing was then weatherd with a black thinners mix and the mould and moss brushed on, then oversprayed again with more water seal.
Can't test it weather wise until the tiles arrive. Door hasps are made from the hindge from a broken pair of Sun Glasses, bolt is just bent rod.
Bram
4
Knowle
That's a neat way to make the guttering, I like the ingenuity:applause: :applause:
silverflyer
248
Here's the one I modeled mine on, in Mayrhofen on the Zillertalbahn in the 1960's
It's a lot longer now having been extended since then.
Here,s a shot I took this year, been every year now for twenty years.
Anybody else been to Mayrhofen, or if you want some more shots of the shed and station let me know.
Steve
I didn’t say it was your fault, I said I was b
1 Jan 1970
29,027
285
D.I.L.L.I.G.A.F
Brilliant there is a shed load of ideas :D
Dave Ottney
1
upstate NY
Silverflyer,
The shed looks great. I particularly like the detail parts you put on the walls under the roof overhang. Sliding doors are great, we here in the States tend to only think of swinging doors. I'm a bit unclear about your roofing, is it made from a sheet of something or individual tiles. Again here in the States we don't have much of that kind of roofing, I find it very appealing and always take notice of tile roofing when I travel to Europe.
One thing I noted was the chimney, is it supposed to be for venting locomotive smoke or for a furnace/stove in the shed?
Again, marvelous modeling,
Dave
silverflyer
248
Hi Dave,
The roofing tiles will be fitted when they arrive from Germany and will take quite a time to stick on, what you see now is only a photograph stuck on for now.
The chimmney is for loco smoke, it would be too big for a stove.
Regards
Bruce.
