Electric point control
RH Prague
Central European. the station pub is Czech !!
28 Oct 2009
396
20
Prague
Warning; probably a dumb question, electrics not my field.
I'm going to install a couple of crossovers. Can I wire up a pair of point motors to the one switch on an LGB 51750 control box?
Thanks!
whatlep
1
Worcestershire
www.facebook.com
Re:Electric point control
Thanks!
Yes: no problem at all. If you're feeling adventurous you can go higher than 2. On my previous layout I had 5 co-acting points off one push button using the 24 volt supply from an ordinary LGB starter set transformer/controller. Worked faultlessly for over 5 years before we moved house and I went over to DCC.
RH Prague
28 Oct 2009
396
20
Prague
Thank you, sir, that's good news
Gizzy
36,154
2,280
63
Cambridgeshire
Yes, I have a crossover at Weybourne South Junction where I've done the same thing.
And I have also used the same techique to switch both points for the reversing chords too....
minimans
Trains, Planes, Automobiles & Shooting
222
67
San Francisco Bay Area
As long as the box has the black rockers it will be fine the earlier box's with white rockers are of a smaller amperage capacity and used to burn out, I know coz I have a collection of box's with burn't switches!!
