Dylanlewis2000
Hello all,
After a bit of help with electronics. I recently acquired a set of starter set coaches with a view to put lighting in them. I have decided to go for track powered lighting as I have a habit of leaving batteries in devices and over the winter they corrode, so with this in mind i have purchased a pair of track pickup wheels.
Using strip LEDs i have successfully installed lighting in both of these coaches however when they go around the track they flicker. To remedy this i was going to install a capacitor, and as i have had a bit of spare time this weekend, i thought that i would give it a crack.
Looking online i can't see any definitive answers to i took a trip down to Maplin to purchase some capacitors. The 'manager' of the store didn't have a clue what would be the best for my solution to i decided to take a range of different capacitors to try with 1000uf 25v being the biggest.
I have wired the 1000uf up and although it does not solve the flicker problem it does seem to hold charge, however this only works with analogue. When i plug the MTS in and try the same coach, it seems to have a bit of a paddy and the safety shutoff kicks in.
So I'm after a bit of advice. What capacitors do i need (size and type) and how should they be wired in?
