KeithT
It is probably a bit late to make this observation but here goes.
Beware if you have bought cheap batteries recently.
Just before Xmas I bought several packs of AA and AAA batteries from the local "no more than a pound" shop.
These are marked "Powercell" with a black body and red top. There are 16 batteries in each pack.
They are unadulterated rubbish.
When did you last have a battery which leaked Sal Ammoniac Solution?
They have leaked into the battery compartments of 4 miniature houses corroding the contacts. The liquid - I am amazed that there could be so much in such a small space - has leaked through onto the surface below. Fortunately, I had placed everything on a cloth otherwise we would be looking at damaged paint/varnish.
On further examination I found that 3/4 of the AAs and over 1/2 of the AAAs were flat and leaking in their packs.
There is no country of origin on the pack but no prizes for guessing where they probably came from, there is only the importers name, ITP Imports.
I know the adage " if it looks too good to be trued then it is" but these are an extreme case.
I have just googled ITP Imports and I see they do a range of goods including pregnancy testing kits.
Well Good Luck with those!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You will need it!
You will need it!
