Dinas Bryn
I have to set up a 2 track section, how wide of board do I need and what sort of materail would you use? Les
Dinas Bryn said:I have to set up a 2 track section, how wide of board do I need and what sort of materail would you use? Les
Philbahn said:Just been out lLes. R1 to R2 centre to centre 7 3/4" (197 mm)
I think problems arise where there is a reverse curve as we found on Phil's layout today. Long and wide stock generally clears his catenary posts except at one point if some stock is reversed. Whereas stock with a long overhang will pass OK forwards, in reverse there is a tendency for the bogie to slew pushing a corner out and causing it to foul the post.Philbahn said:Just been out lLes. R1 to R2 centre to centre 7 3/4" (197 mm)
The plastic composite soffit boards seem dimensionally stable.minimans said:a Twelve inch plank is perfect but a soffet board? I would think it will warp like a pretzle outside, Thats why I used pressure treated 2in X12in Redwood. but if your indoors I dare say something thinner will suffice
Philbahn said:Les think I would prefere to go a bit wider . May be up to 14" just so the locos not on the edge.
Think the best solution is special plywood. They use it on wagon flooring. Just trying to think of the trade name. Don't even think of "normal" exterior ply. Todays ply is like blotting paper. Soaks up water and blows apart in a similar way to MDF when that gets wet. Itwould of coarse need a base or frame work to support it.
If you took the width up to 16" you could get 3 x 8ft rippings out of one sheet plus a bit of added safety if a loco derails
