GAP
G Scale Model Trains, 1:1 Sugar Cane Trains
Gizzy said:Cut my teeth on vacuum devices?
The Helmet Mounted Display on the Apache heliochopter is a CRT....
Valves real transistors with heaters
GAP said:Valves real transistors with heaters![]()
ntpntpntp said:This is a Bachmann loco, right? Does it have a polarity switch? Many of them have one (behind smokebox door?), to switch between NMRA and "other large scale" polarity, ie. LGB. This switch might have been left active even if it's now decoder fitted.
Rhinochugger said:MMMM.......... treading gently on thin ice, as this is in he DCC section![]()
But there's a lot to be said for gold ole auntielog:
one black wire
one red wire
O0 O0 O0 O0 O0 O0 O0 O0 O0 O0 O0 O0 O0
Now I suspect that there are a few fellows who will be able to unravel this little mystery.
I have one of my sections of the layout (the quarry line) as a plain DC shuttle that spirals from one end to the other and back etc with a diode gap at either end for stopping the loco.
It has been working absolutely fine with DC locos and can handle up to 8amps.
So far so good.....
My other layout sections are powered by DCC unit, or DC, depending on what I want to run.
I have just DCC-ed an LGB 0-4-0 D&RGW diesel switcher with a ESU Loksound XL 3.5 board, sound etc (and enabled DC analogue usage in the CVs).
Tested it on the DCC section and everything is tickety-bo...motion, sound, lights, functions etc
As it was one of the locos that usually domiciled on the quarry (DC analogue shuttle line), I then brought it to that line and tested it with straight DC power but strange things .....no sound (I have sorted the sound prob!)........
there is normal motion and lights.....BUT it does not stop after the diode gaps like it did before the installation of the DCC decoder, it just wants to keep on going after the diode gap.
The DC power is from a Train Engineer with PWC switched off ( I tried it 'on' just to see what may happen....confuse the decoder etc... but no difference).
There is up to 22v and plenty of amperage on tap.
I then put a DC analogue loco (same type of loco) onto the quarry line, to see if the diodes had gone west since a few days ago when they were last used.....and the analogue loco stopped happily after the diodes at each end and then reversed after the set time.
So it is definitely something that the decoder on the 0-4-0 is exhibiting whilst crossing the diode gap...
Now I maybe wrong, (more than likely), but I suspect that the decoder is being able to use any 'leakage' of voltage that the diode may allow to power the motor and lights even when it has gone past the diode gap.
If I am correct ....are there diodes with the power and voltage handling, that do not exhibit any leakage?... Schottky type?.......the ones that I have used for years on the DC shuttle are plain old IN4001......
Or do decoders just not work with a diode set-up as found in DC shuttles....
A quandary.... or can I not see the wood for the trees....
