do all stainz have directional headlights
stevedenver
255
recently acquired my first MODERN stainz-20211-#'3' printed on the cab over  "LGB" -highly detailed plastic rods  (all my others and my 2015's are all the older metal rods)
virtually new-no box
via ebay -
so,
im asking if the features are correct for this loco-i believe it was from a starter set circa 1998 or so
this engine has a cab light-no smoke unit-but has the stack designs for an insert-ipresuem the early ones may have been without units
both rear and front lamps are lighted while running, regardless of direction of travel-intuition tells me this isnt correct-
cab light always is on
this version uses 24 volt pin bulbs
im impressed greatly with the allen gear as well as the improved details -really like it
nice and crisp-and a very nice air pump too
comments please
dutchelm
176
N Somerset
You will find the number 3 is the economy loco. No electronics so lights straight on to the power without diodes. No smoke. No plug on the back of the cab. They didn't even paint the dials in the cab.
stevedenver
255
actually it does have the flat plug
and it has an entire backhead of the boiler
room for a slide switch but no switch!
dutchelm
176
N Somerset
All the ones I have come across have been built without a plug. I can show you one with a plug but that is because I added it myself to couple a pair together for track cleaning.
themole
tramways
32
In a burrow.
There are a few change over models that used up existing stock parts. Early versions, both lights lit up either way the loco went. Alyn
stevelewis
39
Buckley NR MOLD NORTH WALES
Yes correct, there were many combinations os Stainz locos!!
The non directional lighting was very common!
stevedenver
255
damnitall mike-youre right-!!
the damn thing simply has a black plastic blank over the area where THERE should be a plug-
i had assumed it was a new slick style of socket cover
wonder why they were so stingy with the early changeovers
ill need to use a red lamp for the rear lamp -always wanted one this way
Spule 4
1
Les États-Unis
Base model for the trainsets I guess. Kind of interesting, but then I have always been a fan and buyer of base-model automobiles.
Never understood the directional lighting on LGB steam, especially the older (not modern DR) stuff. I have removed it on a couple of mine.
