Rain stayed off yesterday for my running day. However had a real disaster as I decided to run with Live Steam and Battery Power. My beloved Jack somehow managed to burn out the Plastic on the Insulating Wheels, worse than this it also melted the Nylon Gear on my SloMo. So Jack is out of action for an underptermined amount of time.
Not exactly sure what happened as a Live Steam savy friend was driving Jack. The Fire appeared to have gone out but what I suspect had been happening was that the fire had been burning through the back of the Smokebox at the back and heat got into the wheels and subsequently the Nylon Gear on the SloMo. The Smokebox is a little loose after Chuffer Fitting many years ago, the tightening screw is pretty imposible to reach. May nee to change this to.a Hex Headed Screw that can be reached by a small spanner. The heat must have been pretty high as the pictures will show, have checked the Boiler this morning and there was water still in it. Filled up the Boiler and no leaks so Boiler is sound still. All very worrying and Jack is now in bits on the workbench, have contacted Terry to ask about what can be done with the SloMo unit and will need acouple of New Insulating Wheels for the front 2 drivers from Roundhouse, though I may investigate turning some new Tufnol Insulating Bushes as replacements as the Wheels are fine.
Melted Insulation Wheels on the workbench.
Trashed white nylon gear wheel (centre of the picture), around 8 or so of the Cogs have melted.
