Disassembling a Pola signal box
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
I need to remove the roof from a Pola signal box I put on my layout a while back. Unfortunately, like an idiot, I actually glued the roof in place rather than simply resting it on top of the rest of the structure and despite some gentle pulling and levering it is staying steadfastly attached to the rest of the building!!!!
Any suggestions for either dissolving or weakening the Pola / UHU glues that come with these kits in a non-destructive manner?
Thanks in advance,
playmofire
23 Oct 2010
8,266
853
80
North Yorks
Warm soapy water might help loosen it.
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
Thanks - i can stick it in a bowl of warm water and Fairy liquid and see how that goes.
playmofire
23 Oct 2010
8,266
853
80
North Yorks
Depending on the design, it may loose other parts too, so keep an eye open for small parts floating away!
4,993
Thanks in advance,
Or you could leave it in the Garden for around 10 years, most glues seam to come unhinged in that timeframe to a greater ir lesser extent. Probably not much help with your current needs!
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
Jon, I did consider this approach after initial attempts to take the roof off met with some alarming cracking noises!
stockers
3,795
65
Nr. Ashford, Kent. England.
Cant recommend this, but just drop it. Mine seem to re-kit themselves with a sharp knock!
Reactions: 1 users
pugwash
impecunious pirate
17 Nov 2009
21,110
1,805
Luxembourg
Don't kill the messenger but Pola glue is bulletproof. Uhu (why name a glue after an owl?) isn't far behind. Modern Uhu glues are made without solvent, so soaking may work, but if you used an earlier solvent-based variety you are stuck.
maxi-model
661
Bucks/Oxon/Northants area
Interesting. From what I read here and elsewhere most peeps don't remove the "weathered" finish properly from jointing areas of these plastic moldings, resulting in solvent based adhesives not providing a good bond. As a result self disassembly should be a doddle on most styrene kit built buildings. Take a careful look to work out what adhesive seems to have been used. I sometimes use an "Xacto" type slim chisel blade in one of their chunky razor saw handles to gently prise apart joints where the adhesive is still doing its job. Just work along the line of the joint gently hammering the blade. Max
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
In the end I used a craft knife blade to "sever" the adhesive and levered the roof off. Bit nerve-wracking but it came away without damage. Note to self - in future don't glue rooves on to buildings!
4,993
Problem with this solution is that the roof may just dissapear one day, this happened to my small alpine Church's pointy one. Still not done a new one. Think the option is to find a mechanical way to hold them in place, perhaps with a couple of small L angles inside and a brass pin passing through a hole in the side and the L.
Ralphmp
6 Jan 2010
1,640
228
72
Herts
England
Good point. I've always thought that assembly and mounting of rooves in both Pola and Piko kits hadn't really been thought through - or if it had, the best technical solution had been discarded due to increased manufacturing costs. I like the brass pin idea - maybe something I can experiment with.
trammayo
4,680
Co. Mayo
Ireland
or hang a weight to the inside of the roof?
Nodrog1826
Professional Idiot
21 Nov 2013
8,989
2,731
United Kingdom
Missing church roof, blame Jimmy Brown...;)
Reactions: 1 users
Bill Barnwell
30 Sep 2017
786
549
79
Ormond Beach, Fl
Thanks in advance,
Phil, I've loosened several buildings, both pola, piko and kalamazoo car bodies using acetone, yes it will dissolve plastic so use sparingly, it does have a very rapid evaporation rate so it's doesn't dissolve thinks like as bad MEK and after you get the hang of it , it works great, Bil
