This project is almost a year old now. It was done before I joined this forum.
I had a Marklin Maxi shunter engine for a while. I got if from ebay for a good price, and I always liked the look of the engine. Maxi line in Marklin indicates that this is a basic engine. The whole body is two moulds, no extra detail, not even windows. Engine is placed vertically and drives a singe axle through a worm screw. Other axels are turned via the side rods. Marklin also sells a DH 500 engine which has the same chassis in red, drive is also similar but with no side rods. I don't this is a model of an actual prototype. DH 500 is a Henschel engine.
Locomotive as sold by Marklin:
Bits I wanted to add are:
- Additional footplate on the front and rear
- Handrails
- Windows
- Additional guards
- Paintjob and eventually weathering
- Headlights
I based my project on the following model: http://www.spur1.de/umbauten/lokomotiven/dhg500/DHG500-im-VW-Werk/VW-Werkslok DHG500.htm
There is a company who makes detailing for this engine: http://www.spur1.de/umbauten/lokomotiven/dhg500/henschel-dhg-umbauen.htm . I already have the windows and try to get some horns and wipers.
After Googling the engine I have found that it was sold to many companies and it exists in many liveries, handrail design. Hence I decided that I will not follow any particular design, but take stuff from here and there.
These are the footplates, guards and handrails done already:
Break pipes:
More handrails:
Handrail is 1.5 mm copper wire, guards are piece of U channel, angle and piece of plasticard. Break hose it again bit of U channel, pipe, copper wire for the lever and wire with insulation as a hose.
Engine had no headlights. The holes are exactly 5 mm so the standard 5 mm LED fits right in. Still have to drill holes for the red marker lights and connect them to the basic digital decoder that comes with the engine.
- Handrails
- Windows
- Additional guards
- Headlights
Break pipes:
More handrails:
