Deck girder bridge from steel
nygma
Hi All, I have started experimenting with CNC laser cutting to build steel bridges. I have taken a simple deck girder design with walkways on each side. I put the design into AutoCAD and got the elements cut from 1 mm steel. Pieces are joined by bits and holes that slot into each other. I soldered my first design and used steel glue for the second model. After it was simple spray painted with primer and matt grey Plasticote paint from B&Q.
These are some of the pieces staight from the cut shop. This is from my first design, cut from mild steel. Second bridge was from galvanized steel
Starting to take shape
Jumping couple of months in time. Assembled, glued, painted with decking:
Class 66 is not the best for this particular bridge. It was designed for LGB or 16mm, it is around 1:20. The handrail is overscale to the 1:29 engine.
Currently I am looking for the next potential prototypes. Do you have a favorite steel bridge?
I personally prefer under-deck bridges as it leaves the train unobscured. So any through arch bridge, under-deck truss or truss arch bridge?
Wow thats brilliant :thumbup:
That is awesome! Where did you go to have the machining done? How much did it cost? If you could get them to make the bits again I'd more than likely be willing to buy a kit from you!
Can you do something like this please.
Cor thats rather splendid and I also may be interested in a kit
We would not like any one to find them sub standard so i will put my self forward to try one free of charge just to be sure .
No need to thank me guys its a cross i have to bare :thumbup:
Very nice work :thumbup:
Personal favourite (sniffle)
If you do produce a kit - at the right price - put me down as interested of Luxembourg (no class clickety-click though). I mean your box bridge, mind you if you can do Friargate I think there are a few here that would fight to get one. :rolf:
:bigsmile:
Wonderful job - the possibilities are endless!
Mick
That's superb.
Glen Wyllin viaduct on our little island would be a nice prototype......
Nice and you beat me to it.
I am moving on from the plastic stuff and you may well see something similar in a bit in stainless steel. The slotting of the bits is always a key, nice job that man.
This is as far as I got initially 1.29 as an idea, I must say i do like you idea of a sheet side and I may copy that.
Time is the issue tho, the alser is always busy. Once again, well done, good economic use of the cutting too.
I got the parts cut by LaserProcess (up in Birmingham). It cose me just under 100 quid with shipping. My models are in 1:32 and the reason I designed this in 1:20 to sell it either as a kit or as a ready made. I have issues with painting (how and where) but I can certanly produce some kits. Let's discuss offline.
This is how I design the structure:
http://nygma.hu/dl/20.274.001_Component_List.pdf
As you can see the cross sections extend all the way up to the handrails. There is also a wide brace at the bottom to ensure that it keeps it shape. Longitudinal sections are made from one peice. This makes the bridge fairly strong. Make sure that you always design the holes slightly larger than the bits. I added 0.1 mm in each side.
I learned a lot from my first design and it is ont easy to get it right for the first time.
