Tim Brien said:
I connected a relay to the track output of my deceased Piko central station. I know that the station works for DCC sound input so figured that there must be some signal to the rails. Not having the correct RMS meter to measure the DCC signal, I tried a DC meter and recorded 11.75 volts (nothing recorded on AC selection). At least there was a signal at the rails. The chosen relay sat there like a lump of plastic with no response to indicate it even knew the DCC signal was present.
Looks like all my relays will need to be bridged for digital operation, effectively taking them out of the circuit.
Tim,
You might just have inspired me enough to carry out some basic physical measurements on DCC signals. Once I have done this I will repost to confirm the following (under item 1) that I believe to be theoretically true :-
1. You can't use a true RMS meter to measure DCC Voltage. You can get an approximation by using the ac range. You need an oscilloscope or similar to measure the peak value (not RMS). If you can measure a DC component then there is either a fault or you have set the Central Station to drive an analog loco.
2. Most relays will operate only with DC power to the coils. Larger devices that switch power circuits using AC coils are called contactors. However I am intrigued by how you have connected the existing relays. Since they are track powered, I don't understand how they respond to reduced voltage unless you have selected a very low operating voltage coil and operate them at over voltage. How are they switched, and what do they do?
3. Importantly why are they track powered? If you are using DCC as track power then the cost of track power per Ampere goes up dramatically, apart form possible conflicts with new technology such as RailCom. Its generally preferable to use a separate supply for continuous loads.
4. Why do you think rectifying the supply to the relay coils takes them 'out of circuit'?
5. Its my observation that combining DCC and DC is a far from simple matter, especially when using 'off the shelf' components that were never designed for dual supplies. Its not impossible, after all men were on the moon before DCC! But it does need a bit of engineering pre-planning. Its not a simple case of disconnecting an analog power supply and replacing with a DCC supply. And you have some technically challenging track configurations.
I appreciate that this does not help you, but you have not given enough detail to allow helpful comment. There is usually a trade off between what you would like and what you are prepared to spend. There are those who like to retreat into their 'comfort zone' of old technology and that is probably a blessing for the rest of us who like to explore what is possible. If I may be so bold, you are certainly pushing the boundaries of what is possible in combining DC and DCC. I just wonder if it is worth the effort? Since some people are more relaxed with DC that they think they understand, I'm not going to suggest they are wrong. But once you experience the advantages of DCC, you may confine DC to test tracks, as I do.
Don
