Markku
I was wondering if there is some practical limit or advice about locating the central station not besides the track.
I won't have an insulated shed that could house the sensitive electronics (CS, power supply) so I'm thinking about having the CS (with its internal booster) and its power supply in some kind of carrying box. The box could then be brought in and out. The box would be brought from inside to the terrace to connect to mains power, and it would have some 5-10 meter two-wire cable (with banana plugs or something) that would be connected to the track, there would be a small interface box with the banana plug sockets inside.
Will the length of the DCC feed cable be an issue for the DCC signal quality or something like that? Obviously the wire diameter and quality needs to be sufficient anyway.
I have ordered the ML-Train or MD mXion MZSpro central station set with WiFi and the WLANMouse handset. Let's see how it goes.
