Hi All,
Got the ECoSBoost yesterday and tried it out. As said in aviation speak - no joy. The CS3 and ESU booster don't communicate. At least not with the current state of firmware/software in both devices. The CS3 doesn't show the booster and the booster's led flash sequence indicates power but no control station connection. I can't check the the ECoSBoost firmware version without an ECoS control station to see if an update will fix the issue. Too bad it can't be done with the ESU Lokprogrammer I already have. The CS3 has the latest update. I should have done more research before jumping! After more reading, the ESU booster wont connect to the CS2 either but it will talk to Märklin's CS1.
The booster came with a 19Vdc, 180w switched mode power supply. As long as I had it I checked whether it might serve to power the CS3. It has the same type 4 pin DIN power plug. The ESU pin assignments based on the previous diagram which is repeated below are as follows:
pins 1 and 3 Vdc+,
pins 2 and 4 power return
Shell not connected.
As tempting as it is, I'm not going to plug it into my CS3. Pins 3 and 4 are what supply power to the CS3 and those would be OK but, I have no idea what pins 1 and 2 connect to.
By the way, KPPX-4P is the Kycon part no. for its 4pin DIN power connector. I ordered some of the same type connector from Digi-Key for $3 apiece. The connector sold by Digi-Key is made by CUI Inc. and has the part no. pdp-40. The pin numbering shown above from Kycon may be a DIN standard as the same numbering scheme is used by CUI for the pdp-40 and by xPower in the AHM series power supplies mentioned in my previous post. I also have a couple 19V, 120w switched mode power supplies coming from Amazon for $36. I'm retired, my time is cheap. So, for about an hour labor and $21 each I'll have my 5 amps to the rails plus a spare PS.
Wont mention what I paid for the booster. Anybody out there need an 8A ECoSBoost 50011?
Phil S.
edited 4/16/17 to correct a grammer error.
