paul delany
Hi folks I bought a few crest ho recievers for use on O gauge but I'm a bit lacking in info about them has anyone wired one up ??????
Hm not sure you will be able to get them working with another transmitter? You would not have the various menu options for linking and setting up names etc.im not sure which frequency transmitter revolution its designed for ,27/75mhz or 2.4 ghz?
I have the 2.4 and the 75 ghz transmitters which one are they designed forHm not sure you will be able to get them working with another transmitter? You would not have the various menu options for linking and setting up names etc.
No darn it I only have the 75 ghz and the 2.4 hand setsfrom the part number, they are 27 mhz, and take a transmitter different from the G scale 27 mhz.
the 2.4 ghz ho version is a part number in the 57000 range.
Do you have the transmitter? Part numbers at end of this page, more info on my site.
Train Engineer - old Aristo systems
Greg Elmassian web site on large scale trains and garden railroads, cigars, and computerselmassian.com
Looks like Greg has answered you question, for the record I was thinking of a transmitter that was NOT a Train Engineer one. That I am sure would give non compatibility as would differing frequencies.I have the 2.4 and the 75 ghz transmitters which one are they designed for
Hi greg thankyou for taking the time to research for me unfortunately I dont have the manualThe chances of you finding an HO 27 MHz transmitter in working condition are slim. Also the receiver works on 12-14v dc, so pretty low voltage in G scale. I did some more research, and i found one place saying it was 75 MHz, so you might try linking...
do you have the manual? I have a copy of it.
hi greg i have powered up the tx and the rx but there dosent seem to be a code recieve button on the 55002 boards so i have no idea how to bind it?I did further research and have confirmed 75 MHz, and that the 75 MHz transmitters, ones sold with the LS 75 MHz decoders and the ones sold with the HO 75 MHz decoders are identical.
So if you have a 75 MHz throttle, it should bind. Watch that voltage though!
Good luck, Greg
Not used to the smaller HO ones but they may be similar. The G ones have a push button switch on a cable that plugs into the board somewhere this is what does the job. Just a simple push not a hold when binding. Do you have any such switch lurking that you did not know what to do with?hi greg i have powered up the tx and the rx but there dosent seem to be a code recieve button on the 55002 boards so i have no idea how to bind it?
Hi greg unfortunately my little manual doesn't have the information but I did find the Reed contact and yes sir you manual would be appreciatedPage 3 of the manual I have has a section:
"how to link the transmitter and receiver"
step 3 says "place the magnet over the locomotive shell above the receiver location to activate the decoder"
I hope the manual you have is correct, if not, let me know and I will email you it... (second offer)
Don't know where the sensor/switch is, but the loco lights will blink when you get the magnet close enough.
Hi greg I dont know what email server you use,my email is delany1967@gmail.comemail me so I have your email address... mine is in my signature.
