Controlling 180 Degree Servo Help Required
Rogersee
Hi Everybody
I want to control a servo to rotate 180 degrees, I've bought a Tower Pro MG995 & check it does turn 180 (by just connecting with power leads). I want to control the rotation using my Spektrum DX6i via a Spektrum AR610c receiver but using this I can only get a standard turn of 60 degrees. My knowledge of electronic is almost zero so any advise would be most welcome. My thought is to put in a "speed controller " to amplify the signal to the servo & there by increase the amount of turn, would this work ?
Thanks for your time
Servo position is controlled by the pulse width of the control signal..
I am not sure what you mean by a 'speed controller' in this sense?
Thanks or that... Very useful..
Squirreled (sp?) away for future forgetting where I put it! ;)
