CONNECTING AND PROGRAMMING MASSOTH NAVIGATOR TO CONTROL LGB UNCOUPLING TRACK
TONYWARD50
Tadpole sexing</br>
I have tried in vain to understand the instructions for connecting and programming the Massoth Dimax Navigator so that it will raise and lower an LGB 10560 uncoupling track via a Massoth Swith decoder
Can anyone explain in words of one or two syllables how I do this, cos I am very confused....
Cheers
Not sure what you mean tony
but you should treat the ramps exactly as points. are you saying
[*]You cant get the navy to operate anything[*]cant get the ramps to work[*]cant progam the ramps to a number a few more details on you problem would help other to respond
Steve
It is connected and operated in the same manor as a normal point motor. On the Navigator, select the accessory address and use the Left/Right buttons to raise/lower the ramp.
Sorry, I should have said that after connection I cannot program the ramps to a number. IN the Navigator manual it mentions "Input CV! followed by the number you want to assign, e.g 20 means 17....etc". I may have the wrong section so this is where I think I am going wrong.
Tony, Are you using MTS3 or Dimax?
I will try and find some time later to sumarise the required CV settings in a similar way I have done for the LGB 55025 switch decoder. Tony PM me your phone number and I will try and call you later when I have a bit of free time.
Thank you for all your erlp. The problem seems to have been a faulty Massoth Switch unit. Now programmed and ready to go !
