Zerogee
Clencher's Bogleman
Having fitted the new TL45 Pfiffi with her crew this morning (see my thread in the "figures and accessories" section), it was time to fill the coal bunker..... Trainline do supply a bag of crushed real coal (at least I assume it is real, it leaves black coal-y marks everywhere!) but the lumps are still WAY oversized for G scale - they might look OK if I ever do anything in 7/8ths scale! Rather than try to crush it down smaller, I simply used some of the fake coal "vase filler" from Dunelm that I mentioned finding a year or so back, which as you can see is perfectly sized for G scale loco coal.
First picture of the operation is lining the bunker with a double thickness of clingfilm, then a thick piece of black plasticard (actually two laminations of 2mm sheet) is laid loosely in the bottom of the bunker. This helps to press the clingfilm into the corners and will give the finished "coal load" piece a bit of overall strength.
Then the bunker is filled with a suitable amount of the vase filler "coal".....
Then, with the aid of glass pipette, a 50/50 mix of PVA glue and water is dripped all over the coal, and gently worked in with the end of a coffee stirrer until I was reasonably sure the glue had settled throughout the coal load. Now the waiting part, I'm not going to disturb it for several days.... More pics to follow when it is all dried and I can remove the clingfilm!
While I had the PVA mixed, I decided to do the same for the bunkers on both my TL45 Mallets (5901 and 5902) - these are a bit easier than Pfiffi as the Mallet bunkers unscrew and can therefore be done off the locos; the Pfiffi bunker has no visible screws, it may simply be clipped in place but I didn't want to apply too much force to try to shift it, so that one was done in-situ.
Here are the two Mallet bunkers filled in the same way, again I will do some more pics when they are dry and replaced on the locos.
