Coaling Tower at Chama
Gramps 77
This may not be the proper forum to ask this question. I ask for your indulgence. I'm a descent model builder I know nothing about all of this computer stuff. Even less about how to use this forum properly. My question. I am going to build a model of the Coaling Tower at Chama. I am putting together the various pieces. I am looking to purchase the hoisting apparatus. The sheaves the pulleys. Is there anywhere I can purchase these parts. I appreciate all your help. Thanks. Gramps 77
Hi Gramps77, I have moved this post to a nice new thread for you. I hope some of out posters will be able to help.
Ozark Minatures. They made a laser cut kit of the Chama coaling tower not so long ago. I tried to get one without success. They do a wide range of fittings in their range. Perhaps some of those used on the Chama kit are available to order. Have a word with them. They offered both 1:20.3 and 1:24 versions. Max
Other than what has been suggested may be
www.walthers.com, www.precisionscaleco.com. As you can see from mine I hid the detail inside the tower, outside it's hard to do details that are complicated just do to the environment, leafs, rain, birds, squirrels, etc. Just finished a sawmill and went way to over board on it, probably be a lot of cleaning. I know the tower that Pola did of the Chama one is over powering and dwarfs everything else on the ground, good luck with your build, Bill‎
Thank you for your help. I do appreciate it.
I have purchased the plans for the coaling tower from Brewer Railroad Plans. I was looking for some clarification on the coal pit. The plans have a pit plan but no elevations. The plans in the N.G.& S.L.G. by W. J. Ewell have a pit plan and a cross section but no measurements but they can be scaled out. An article in Model Railroader Mar. 1960 by Len Madsen has elevations plus measurements. The measurements on all three drawings are different. Is there a common denominator. I read somewhere that one modeler had the plans from the R.G.S. railroad. I don't know if they are available at all. Never followed up on it. I need your help in solving this problem. Thanks. I anxiously await your replies.
Concerning the Chama Coaling Tower. Hopefully someone will be able to answer my question. How do the cables that operate the coal buckets penetrate the wall of the shed that house the machinery that operates the coal bucket? It is not shown on the plans I have nor on any pictures I've seen. Thank you. Gramps 77.
That is one piece of magnificent engineering !
I used a playmobil actuation set ( 15 euros) part number 5556 apparently still on the market.
The hoist consists of a totally home made winch and a Playmobil electrical actuation set selected for several reasons:
- actuator delivered with its control box avoiding to design one control circuit and integration into a box
- actuator fitted with an end stroke torque limiter avoiding breakage risk
- quite acceptable torque. This hoist lifts 200 grams at hook level
The winch is made of wood.
The 2 side uprights are bored together at a wood rod diameter dimension creating the winch drum.
The shaft axis is thus properly done.
The liaison with the actuator is made with a small plastic tube providing an additional torque limitation
as installed in the housing at the crane top
My first design was to create the big hole in the hoist plate as I believed the rope should be able to move freely. It is wrong , it is better to have a small hole to guide the rope in the right place in the midle to move the bucket.
