wandgrudd
Hi I have control of the feed rate speed, the spindle speed, max is 9000 rpm, and the number of passes cutting depth per pass sets that, the best looking one so far on my tests was the 20mm / sec feed rate which was cut with two passes 0.5mm per pass. The next test was going to be a single pass, 1mm cut depth and then play with the feed rate speed and the spindle speed to see if I can improve the edge of the cut. I am sure with a bit more testing I should be able to get it to cut patterns for me cleanly.
Plastics always bait of trial and error, if you have the power one pass will always work best in plastic with slow rpm. not that its much help but i much prefer wood much less messing about.
