Typically, real bush tramways were built going uphill with the empties. Given the risk of runaways if you are hauling loads uphill, astute operators pushed loads uphill... better to have braking power on the downhill side of the train.
Yes one of my Cherries did the same trick, fortunately I managed to get all the suckers out from the persistant one that was nearest the house. This had had its roots well cut back when an extension had been built so had bolted towards the pond. These got sorted when I did a lot of replanting around the pond.We have a flowering Cherry in the garden..
The Girls called it 'the Bee Tree', for pretty obvious reasons..
It has small 'curly' branches, from larger limbs. These seem quite brittle, and I have to clear them before cutting the grass.
Other problem, the roots seem to 'run', are quite shallow, and they throw 'new' trees.. I did spend a couple of weeks, off and on, a year or so back digging these roots out of the far-end of the garden..
A thankless job in Staffordshire Clay!
There was a loop there, but I ripped it out to use the turnouts elsewhere and to (hopefully) make more interesting (complicated?) operation.a run round loop?
If a coupling snapped you could have an uncontrolled runaway.
Ril
I think I'll go with that Operating Plan.Yeh, but its a logging line. They don't worry about details like that.
No I won't really wreck it. It has already had 3 lives - first as Ghost Gum, then Sandstone and then Ti-tree. Where next I wonder????Sad, but it comes to us all..
I hope 'demolished' is actually re-located? - It would be a shame to destroy the building..
ATB,
I started this Topic 2 years ago when the ‘round-the-yard’ run was severed by a neighbour’s tree dropping branches and damaging a bridge.
I had then planned to make Ti-tree into a terminus station and actually replaced some track and started building a turntable. BUT...
The baseboard at Ti-tree is 42’ long and made of fibro over old fence palings. About 6’ of the righthand end has now been destroyed by another falling branch. I am very worried about even being in that part of the yard for fear of being hit.
The track is mostly handmade, brass rails nailed to wood sleepers and is 17 years old. The nails are rusting and it is starting to fall to pieces. It will need a lot of work to fix.
The rest of the layout is 25 years old and is needing more and more maintenance. I have less time to work on, or use the train, because of my wife’s illness, so I have decided to remove the whole of Ti-tree and the line from Lilyvale. The truncated layout will still provide more than enough work and operations for me.
Here's the video of the last trains at Ti-tree
And the next day Pauline and I visited Ti-tree for the last time, before the building is demolished.
(we are cardboard cutouts!)
