Claptowte Railway - Gernise End Goods Office
David1226
Part 1
Having previously built a couple of Kippo Models G Scale cast resin buildings, I have been impressed by their quality and simplicity of construction and the amount of detail that goes into the kits. Several of the parts are modular and appear in more than one kit. There are several versions of a basic line side building and I opted for the version with double arched windows in one wall and a door in the gable end wall. I decided to obtain one of these and build it as a Goods Office for Gernise End Station, to complement the various goods handling facilities.
As with similar kits I had to start by cleaning up the component parts to remove any moulding flash. This was achieved by scalpel, files and wet or dry paper. All the parts were then given a good wash to remove any dust or mould release agent.
The wall mouldings are designed so that the courses of bricks interlock where they meet at the corners of the building. A little bit of additional filing can be required to achieve a near perfect fit. I say near perfect as there will still be gaps here and there. Having used superglue to assemble the walls, Kippo Models suggest the use of car body filler pushed into the joins, which can then be sanded and scribed. This is the method that I used on the two previous Kippo models that I have built, the Station Building and the Toilet Block. The car body filler is very smelly to use and I always have difficulty judging the correct amount of hardener to use, thus it takes a long time to set.
For this model I searched for an alternative. Having superglued the walls together and filed down any overhanging or protruding bricks flush with the surface of the wall (most of them actually), I used DIY grab adhesive, the type that I have previously used to glue skirting boards to walls. A small amount on the end of a finger can be rubbed into any gaps to obtain a smooth joint. Grab adhesive does shrink slightly as it dries, so you may need a couple of applications in places. Before the filler was completely set, I used a point (an old dart) to re-scribe the mortar joints on the corners. I also ran some grab adhesive along the internal corners for extra strength. It does the job with no mixing and no smell but do remember to wipe your finger before you pick your nose.
The assembled walls with corner joints filed and filed, ready for a coat of primer.
The shell of the building, primed and ready for painting.
The painting of the brickwork was carried out in the same way that I had painted previous resin kit buildings. The method that I used was to treat the overall grey plastic primer as the mortar colour. The raised texture of the bricks was painted by means of a sponge wiped across the raised textured surface of the bricks using different colours and gently dabbing and blending. I used some white sponge wedges, intended for applying and blending makeup, £6 for forty from Amazon. I cut a wedge in half as half a wedge was big enough. The odd bit of detail colour was picked out with a paintbrush.
Part 2
Having painted the brickwork, including the chimney stack, I painted the interior of the walls. Once this was done it was a matter of pre-painting the remainder of the component parts prior to final assembly.
The next assembly was to glaze the painted window frames and door and glue them into the building. Before gluing in the door I also added a Pendle Valley Workshop brass ’Goods Office’ sign to it.
Following this, the roof was added. The unpainted, but primed, component parts of the roof were glued on, then painted. When dry, the remainder of the construction was straight forward, gluing on the guttering, downpipes, facia boards and completed chimney stack. This completed the kit as supplied by Kippo Models.
I then went on to add my own embellishments, starting with lighting. I added a lantern to the gable wall above the entrance door and an internal light in the centre of the room. Both lights are 3 volt LEDs powered by a AA x 2 switched battery box mounted inside the building.
I added a set of fire buckets to the wall below the windows. These are an etched brass item, the buckets being cast white metal, supplied by Garden Railways Specialists (GRS). On the wall, above these, I glued a brass Fire Bucket Warning sign from Pendle Valley Workshop.
I applied this strips of masking tape around the base of the chimney stack, to cover the gaps between the roof tiles and the bricks, to represent flashing. I gave this a coat of white PVA glue to seal it, prior to painting.
The last embellishment was a pair of scratch built ‘Gernise End Goods Office’ signs. The boards and framing were constructed from plasticard with the frame scribed to impart some wood grain. The signs themselves were drawn using Microsoft paint and printed on card. The card was glued on using silicone glue so that in theory it should not be too difficult to peel them off and replace them if faded or damaged. I have not sealed the card in any way as the model is intended for indoor use only.
Here is the finished model.
The AA x 2 switched battery box powering the internal and external lights.
Excellent work as usual David. :clap:
Those fire buckets remind me of a cartoon in four foot eight and a half and all that. One was labelled fire, another water and the third fire water. A hopeful native American was approaching the latter!
Part 2
:clap: :clap: :clap: :clap:........:clap: :clap: :clap: :clap:
The Goods Office has some fresh air in the garden, 18.4.2021
