I am about to embark on converting one section of my layout to have the option of DCC (with a DPDT switch for DC/DCC operation). Will the 1200Z be able to also run the other two distinct separate sections of my layout if I choose.
I want to keep the sections separate, as they are now, so that they can be controlled by DC when I wish (visiting locos, non-chipped locos etc etc.)
If I do give the other two sections the option of switching in DCC, I was thinking that parallel connections to each section from the 1200z would be the order of the day. I realise that the power will be divided accordingly but just wanted to check that the central station was fine and dandy 'sharing' its output, both power and also DCC signal.
I have though about the option of 'temporarily' connecting the three sections together when using DCC so that there would only need to be one feed from the 1200Z but this could be forgotten about and obviously lead to problems when DCC is switched out and DC is switched in.
