ebay mike
When I was in Poundland a few months ago looking for a bargain I found inspiration so I bought four and put them away for when i had time to investigate further. Until now, any videoing has been done with a VHS camcorder secured to a Playmobil flat wagon with large rubber bands. This camera tripod was designed to hold a mobile phone. I was convinced it could go further. Having removed the legs the mounting bracket was screwed to a suitable piece of 5mm plastic and the whole assembly fixed to a standard ToyTrain chassis using the existing mounting holes and screws. Gives you a temporary unit to use which can be easily returned to it's intended function. The chrome bar with the rubber finger grip is sprung and holds a mobile quite securely. I've shown a dashcam and a 35mm camera (with video option) in place. Yhe gimbal style mount gives adjustment in all directions and can be fully rotated. All I need to do now is check how steady the picture is and/or if the anti-shake function really works. Pics in the next post if not found below.
