Calling RhB Ge 6/6 II owners LGB 22062 or 22061 roof damage
palmerston
trains
Ive just opened up the box which contained my new LGB 22062 Rhb Ge 6/6 II green loco. I noticed a small piece of braun plastic. It turns out to be from one of the insulators on the roof. Can someone post a picture here so I can see what I'm missing or missing?
You can see on your original pic where it has broken off, it is the tab to hold that part in place in the slot.
You should be able to manoeuvre that piece back into place. A dab of PVA glue carefully applied with a toothpick (or similar) will be quite adequate to hold it in place, but not so tightly that it can't be replace at a later time.... if that's what you want to do.
Yes, i know. Lifted each braun part so check which part was loose. The "wiring" seems to have a loose end, so i thought maybe i am missing some parts but not.
P phils2um thanks for the pictures.
The part might have been broken by someone forcing the top styrofoam box insert on backwards. If you check inside the foam insert carefully you can see it is directional. I marked my foam top with an arrow pointing to the front (loco cab I end) just to make it easier when putting the loco away.
