seigezapf
I’ve been experimenting with trying to come up with a small, simple battery system to fit into some small locomotives (e.g. LGB 2063) that I have.
I am using a Spektrum DX5e transmitter and Orange DSM2 receiver.
For the motor I am using a Pololu 18v15 Simple High Power Motor Controller. For power, a Tenergy 11.1v Li-ion battery. The motor controller connects to the "Throttle" port on the DSM2 and supplies 5v from a built in BEC.
I wanted simple motor sounds, so I am using an ITT sound board. The board is powered by the same battery with a Turnigy Receiver Controlled On/Off switch spliced into the positive power wire. The Turnigy is connected to the "Gear" port on the DSM2 and controlled by the channel 5 switch on the transmitter.
When I actually install it I will include a main power on/off switch, lighting, and charging jack. I also am deciding on speaker type and placement, though I am leaning toward placing it under the cab roof.
So far the system works nicely and is very small.
Here is a rough diagram (Turnigy switch labelled "TEN").
So this is a work in progress. I can post the installation when I get that far.
Craig
Craig
