L.N.R. said:
Hi Peter, I built my tribute to Mr. Brunel (see Pic.) using well seasoned OB hardwood (eucy. regnans) for the three main beams, and treated pine for the inclined bents, and decking. There is a better type of treated pine, not using the old copper process. I tend to buy it in the form of decking boards (70x20). The bents are nailed and glued, I confess I didn't even use water-proof glue, then gave the whole thing a liberal coat of sump oil. It's been outside now for 3yrs. and is as good as the day it was put out there. It hasn't warped, split, or moved in any direction. I is a removeable section and has to line up with 4 pins and never fails to do so. Having used a lot of jarrah in my life, I have found it surface checks (splits) within 45mins. in the sun, when used in small cross sectional areas, such as you would use in a bridge, larger pieces no problems, though I would suggest a bit overkill regards choice. PM me if I can help you with any details,
Grant.
PS bridge in full sun all day.
